Boat information help!!!! / boat id
Del25
So I just bought another boat project. I've been lurking on this forum for awhile , and I finally have a question that I can find any answers too!
So
What I know:
It's a 1987 fiberglass boat made by citation boats inc.
It's 17' long
Open bow
The inside of the boat has a fiberglass liner
Split windshield
Hull iD #fsjsr039a787
It has a 50hp merc outboard 3 cyl #0B206468
So my question are , what is this boat ?
It doesn't have a coastguard plate anymore anywhere on it, so I don't know the max hp, max people and gear ratings . I would love to have this info on hand
Del25
Look thru the 1987 Citations listed here
http://boatspecs.iboats.com/Citation_by_Sea-Pro_Boats__1987/bp/54br1110y
Or here
http://www.nadaguides.com/Boats/1987/Citation-Boats-Inc
And find a model that has specs that match yours, then search for info on that model.
Thank you for your reply!
I've looked through these I have a couple questions .
Is citaions boats inc the same company as citation by sea
I have it narrowed down to it being called either the center console 17' which says it can hold a 90hp. But it's a split window 17 in another category doesn't have any information listed for hp and weight capacity.
Sunken Ship
I thought law required a HIN after 196x or 197x. Anyway, these are not always on a plate, but mught be imbedded in the fiberglass. HIN can be embedded on the upper-right on the rear of the boat.
GA_Boater
The HIN is in the OP's 1st post. And HIN's started in 1972.
jbcurt00
FSJ
HIN DecoderOur HULL ID Decoder breaks down the Hull identification number into the following information:
The HIN or CIN you have entered meets the Current-Format HIN format. It might also be a type that contains the country code and thus the boat comes from USA or Other . The serial number of the HIN is SR039 and is set by the boat builder. This boat or vessel has a Certification Date of (7) and a Model Year of 1987 with month of build (January) based on the formatting of your hull_identification_number (HIN) .
The manufacturer identification code (MIC) of your craft identification number (CIN or HIN) is FSJ. This MIC (FSJ) stands for the company name Citation Boats Inc which is currently Out of Business. This boat manufacturer has other company names (FSJ sometimes goes by these name(s) Fiber Skiff Inc, , , or .
This company (Citation Boats Inc) is owned by Gary Marles and is located at PO BOX 1799 in COLUMBIA state of SC. It manufactured this vessel and placed you HIN or CIN on the hull. The Parent Company for this boat maker is (). Citation Boats Inc has started making boats, yachts and other watercraft as of 12/02/1977 0:00 and went out of business on (4/23/2003 12:00:00 AM) in the following country: .
Make sure to compare the date of boat manufacturing with the dates in which the company was actually in business.
Citation Boats Inc, based in South Carolina. The iboats reference to Citation by the Sea was the only 1987 boats listed under any of our Citation listings.
The OP had the HIN, required post Nov 1972, but it doesnt decode to provode a model.
If its a bow rider, split console or split windshield, use that modelxs name/number and search for a 1987 Citation Model: 1700XJS (or whatever model matches your boat). That should give you at least 1 listing that provides Max wt/pass capacity and etc
