Lancer76
Thread starter- Joined
- Jul 23, 2017
- 121
This summer, I purchased an almost wonderful 1976 Chris Craft Lancer 23'. The boat is equipped with the original Mercruiser 233 (Ford 351W) with a MR-1 outdrive and was run in fresh water. Prior to my purchase, the boat was covered, but not run for about 2-3 years. When I got the boat, I went through the ignition and changed the points, condenser, plugs and wires and adjusted dwell. I also changed the stern drive impeller(all but the lower portion of the impeller housing), lower unit oil, and engine oil. The impeller I swapped out had disintegrated. With that done, the engine ran wonderfully on the hose. Temp never went above 150 F.
I launched and found that with higher RPMs the engine temp went to greater than 180 degrees. It would cool at lower RPMs. I could putt putt around all day without overheating, but could not go above 1.5K- 2K RPM without rising temps.
Since then, I have replaced the entire lower unit pump (complete housing), searched for and found more old impeller, replaced engine circulation pump (old one was weeping), drive belt, T-stat, and starboard riser. I also took off and cleaned port riser.
I only swapped out the starboard riser because the temps on the starboard riser were the highest, so I thought their might be a fatal restriction. I used an infrared thermometer for engine temps. I have run water through the engine and cooling hoses with a garden hose, and I don't think there is a restriction, or at least I don't get back pressure.
Took back to the lake and same thing. No better. I did take of the raw water supply hose off at the engine while on the water at idle and I thought the flow from the lower unit seemed meager, but I didn't measure it.
I am wondering about water supply from the sterndrive to the engine. I took off the outdrive today and disconnected the hose at the engine and ran the hose down it. The flow from the engine side of the hose to the sterndrive is impeded somewhere and I get back pressure. Is that normal? Should I explore removal of the bell housing to check for lost impeller pieces. FWIW, the PO said he never had this issue. There is no oil cooler on this boat.
How should I proceed to get this thing cooling correctly? I feel like I am not doing this in the most logical fashion.
Thanks.
Thanks.
