Yupitsnuge
Thread starter- Joined
- Aug 13, 2017
- 7
I have an 18' maritime skiff with a 99 johnson outboard. I haven't used the boat in about 4-5 years. Before I quit using it, I would have a hard time trolling without the motor dying and then I would have a hard time getting it started again.
I wanted to use it this year so I drained the 26gal tank, installed a new primer bulb, fuel filter immediately after primer bulb, new fuel filter on engine.
I got it started and took it for a low speed cruise to dinner. Right as we were about to pull anchor an hour or so later, the motor wouldn't start. Cranked and cranked, nada. I gave it some time and tried again, nada. Finally i got it started and hauled ass in. I figured it was dirty carbs from sitting so long. After opening them up, I would have thought they were brand new! I rebuild them anyways.
After I put them back in, I primed the bulb and noticed that as it was pumping fuel into the filter in the engine cover it would shoot right back into the fuel line. I also noticed some gunk on the bottom of the filter. It separated from the fuel. I'm assuming it was water. I replaced that filter. I also ran a new fuel hose on top of the deck just in case there was a leak under deck which was allowing water in the line. I got the primer bulb rock hard but would not push fluid into the new fuel filter in the engine case. As soon as I got about a 1/4" of fluid, it shot right back out. I removed the gas cap on the fuel tank thinking it was creating a vacuum. Still wouldn't go into the filter. I then replaced the quick disconnect thinking maybe it was that. Nope. I left the far side of the fuel filter off (fuel pump side) and pressed the bulb and it easily shot fuel out of the filter without and resistance. I also tried cranking the engine and it cranks but will not kick over.
Here's where I'm at now. It's as if there's a blockage after the fuel filter under the engine cover. What do you think is wrong with this engine?
I pulled the fuel pump out thinking I may have to rebuild it and when pulled it out, some fuel came out and then a good shot of water came out too. I opened it up and everything looks good inside.
I noticed a soft spot on floor port side right next to leaning post. Someone said I may be leaking fuel from the fuel line under deck and also absorbing water and that's why I have water in the engine fuel filter, but not on the tank side fuel filter.
Any help would be GREATLY appreciated!!
