- Mar 8, 2009
- 43,595
The motors use the same Delphi ECU as the GM truck/autos but they are not programed the same. You cannot put one off a truck and have it work on the boat.
Its very unusual for both ECU to do the same thing. They both supply spark but have no ground pulses going to the injectors. There is 12V on the Pink wires and while the engine cranks the Blue or Green wires on the other side of the injectors do not pulse to ground?
The next thing is get a paper clip and a 12V resistor and see what the ECU shows for codes
