I'll absolutely leave the internal of the LU to others.. I DO suggest you follow others advice before mine because I'm still new, but I also have a 71 50hp Hydro-Electric.
As far as your question about the solenoids and the switch..
No, there is no safety thing that limits or cuts out the prop in reverse..
Forward is the default if no power is to either solenoid.
If power is supplied to the green wire only, then you should have neutral.
Sounds like that is working fine..
Power to BOTH green and blue wires is reverse.
It's possible the shift switch has an issue. IF (and I do mean if) it has an issue, it'd probably be providing power to the blue wire for the reverse solenoid.
If it's intermittent on the blue wire, then it'd clunk in and out of reverse/neutral..
I'd check resistance on the solenoids by using a multimeter on green to ground, then blue to ground..
Both should be about 5-6 Ohms...
Then I'd check continuity from the shift switch when in neutral and reverse..
The big problem is IF (Again big if) the shift switch is bad, it's no longer available, and costs $$$$$$ if you can find one..
My shift switch was toast, so I came up with a low budget solution which works well for me, so if you find you have a switch issue, let me know..
I'll point you to what I did if you like..
Again.. I'm NO EXPERT here.. racerone IS a pro.. So are many others..
I only offer this since I have the same engine too, and went through some of this myself...
For what it's worth...
