e40elccs clicks while going in foward gear
97SSX
Just recently bought a 16ft basstracker with a 40HP Evinrude, the specs are; E40elccs, 88 model. I bought it from my cousin and have been around the boat a bunch, well taken care of and never given us any major trouble. It has ALWAYS clicked while putting the gear shift in fowards, it recently haa gotten very bad and "jumpy". When i attempt to launch in a no wake zone i have to go back and forth unti it essential grabs/slams into foward gear. Then it runs fine, it planes out and doesnt hiccup and i cant feel anything slipping in the motor or lower unit. Well yesterday it wouldn't go into gear at all, only reverse but i couldn't get it more than slightly above idle in reverse...So, when i got it home I spun the prop and it will spin both ways in fwds and neutral, but wont spin in reverse because now it wont shift into reverse at all! I have checked the cables but am unsure on whats proper procedure on getting in correct. Also if its worth anything, the lower unit oil was changed when we got got it, only been out 20 or so times since the change. This is my first boat so im a little lost but have my whole lifetime dealing with cars, engines and all things mechanical. Just looking for some pointers, Thanks.
Also, the engine still runs fine, it fires right up, idles fine and will rev, but just wont allow me to shift into gear.
F_R
I suppose the first thing to do is disconnect the cable from the motor and see if it shifts ok (manually) at the motor. If it does, figure out what's wrong with the control.
97SSX
I will try tomorrow morning. Im assuming maybe internally the cable has snapped, or at least that's what im hoping. The nuts on those cables did seem a little loose at the lake but who knows. Its funny, the only problem this boat gave my cousin when he owned was the bilge pump gave out, and occasionally the batteries would die. I got it and only 4 times on the the water and this happens! Lol
97SSX
Okay so, upon further inspection, the cables looked fine... however i did a little adjusting to them and now i can manually turn the propeller both ways in neutral, fowards in fwd (its hard with the plugs in) and it locks out trying to go backwards, vice versa in reverse. I also just purchased some quicksilver high performance lower unit oil that ill be changing tomorrow! Hoping to try again monday to see if i fixed the problem!
Drain the gear oil.----These lower units have a history of gear failure.
97SSX
By drain i assume you mean a typical oil change? I currently have two qts of oil, the pump tool, a drain pan, some rags and a philps and regular screwdriver. I will inspect the oil condition as it drains. Hopefully its not milky or ill be replacing the seals next..
97SSX
So i drained the oil, looked fine, not milky, good color and no flakey paste. Put the new oil in, and adjusted the cables. Went to the lake and everything is fine now! Thanks for the help guys!
