So I'm at a point where I don't know what to do next.
I'm hoping someone can tell me some reasons why my motor could be having trouble turning over. Both the electric starter and me both have major trouble getting the flywheel to rotate when trying to start.
Plugs out and it's fine. Almost as easy as my 9.5 sportwin.
The starter can rotate the flywheel but only at about 1 rotation a second or so. It gets resistance at what seems to be the compression strokes.
I know the coils aren't rubbing on the magnets because I fixed this already and torqued the flywheel to 60lbs afterwards.
The plugs are also not hitting the cylinders. I checked
I tipped the motor up and poured some oil in each open cylinder and used the starter without the plugs in to get it lubricated in there. It seems that most of it poured out into the area with the shift arm linkage and water pump.
I think the compression reliefs are mostly gummed up. They will hiss slightly when I rotated by hand and engage them.
I also hear a similar hissing internally at one point during the rotation of the flywheel.
The flywheel will encounter a lot of resistance that builds up and if I slowly rotate through it it will spring forward a bit then go back to the resistance.
It's in neutral when I try all of this
Any ideas? Could something be plugged up internally to cause this?
The impeller seemed to be in functioning order when I checked it out. Not sure when it ran last. I was told a year or 2 ago when I got it. Carb was very clean. It was winterized.
