need some help guys i have a 1990 rude 120 that has a rough idle heres a video please note i did not give it gas in the video i put a new fuel pump and spark plugs on it any help would be greatly appreciated
What meter are you using to check this voltage ?----Tester as per a factory manual ?
yes indeed...best to start from timer base and stator and work your way down in the testing....I see a DVA adapter in someone's future.Dont forget the timing base, that could be poked
