Hey all,
New member and first post. Be gentle. lol
I am resurrecting my 1984 Evinrude 115/Mako 17 , from 10+ years of inactivity.
I wont go into what all I had done to the motor upon "storage" or what I have done to bring it back and live.I DID replace the water pump and housing already BEFORE starting the motor.
I have gotten the motor to run and idle fine with the hose and earmuffs.When doing so I checked the cylinder temps with my hands after a few minutes. The port side,I was able to keep my hand on with no problem. The Starboard, was hot to the touch. I shut it down right away.
I am trying to figure out whats up and in doing so, I removed the hoses from the heads down to the thermostats/bypass manifold. I had let it cool down and restarted just for 10 seconds to see if any water was coming out of the head of the starboard side and THERE WAS NONE. Well, maybe a tiny trickle but thats it.
My question is, does this mean that the head is occluded,poppet valves or whatever are stuck ,etc??? I would assume that this is so, since the port side is flowing fine.
I believe the thermostats are original( believe it or not) as I am the second owner and have owned it since 1990.
The water flow is basically from the water pump, up through the heads, and then down to the thermostats/bypass valves and out of the bottom of the motor ?
I'm thinking from what I have read that I may need to remove the head and replace/ clean parts and re-assemble with new gaskets, etc??
Thanks for any help and advice .
Craig
Craig
