No spark with a tester but spark at the plug ????
rodknee1231
Ok so still have no spark. On any cylinder. I pulled the flywheel. Check the triggers for resistance check multiple points of he Motor ant all ground wires back to the battery for resistance. I checked the stator to make sure it only had resistance on the magnets not the frame. Checked the battery cables themselves. Made sure everything has a good ground. The purple wire has 12 volts. The only thing is either all 4 triggers need adjusted. Highly unlikely. Or my battery is just bad even though it tested good which I've had happen before. Or the starter isn't cranking fast enough. Next step is to try a different battery. Don't know if an automotive store can test this starter. If anyone has any more ideas please speak up. I need to get this running I need to sell it to pay for a surgery.
rodknee1231
Ok did a little more testing I followed what cdi troubleshooting instructions I could with the type of meter I have. The trigger wires all ohm out within spec. And I swapped the stator with another used one I have. I took the batter out of my Jeep and connected it to the battery in the boat for extra amps. I know this motor is turning fast enough to produce something. Still have no spark. Now everything is pointing to stator or power pack.
Fed
Did you try it with the stator leads (yellows) disconnected?
Fed
The stator leads go to the rectifier so same same but you may have a sneaky bridge on the terminal block for the tacho signal wire.
Disconnecting both the stator leads from the terminal block is a way to be sure.
rodknee1231
I'll try that. What are the odds a wire short or trying to start with arcing or bad coils has cooked my power pack,? I have my old one still I may put it on for kicks n giggles. I'm just at a loss here
rodknee1231
Yep. That's what I'm doing trying to rule things out but I'm getting no where
