burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
Going to be re-installing my freshly repainted, new gasketed, new water pump impeller Gen 2 in a couple of weeks. Before doing so, I have just a couple of questions. I have a new drive gasket which also came with a couple of small rubber O rings. I assume one is for the gear lube monitor/reservoir passage and another for the water passage. Would the others be for the drive shaft that goes into the bell housing?
Also, it says to "glue" the O ring for the water passage in place - do I need a true glue or could a dab of grease be used to hold it in place?
Finally, do I need a specific Engine Coupler Grease for the drive shaft into the gimbal bearing? I see that Mercury does make one for that specific purpose and I've heard conflicting opinions on whether 2-4-C or marine grease would work.
Thanks guys, cheers to spring and summer getting to us Midwesterners quickly!
