auscarter12
- Jun 19, 2015
- 59
I have an early 70's model Aristocraft 19 with a Mercruiser 165 and a Pre-Alpha outdrive. This past season, the reverse gear went out. We tried cable adjustment, cable replacement, etc. to no avail. Finally, I decided to have it looked at by a mechanic and it was determined that the clutch in the lower unit is worn down to the point that it won't engage reverse gear. I have been quoted some pretty ridiculous prices to have this repair done. To me, it seems simpler (and cheaper) to buy a used lower unit with a good clutch in it, install it, and just chunk the old lower unit. Has anyone done this before? And if so, do you have any pointers? Also, does it need to be a Pre-Alpha lower unit, or can it be an Alpha One/Gen 1 lower unit?
