Pressing Bearings Onto the Drive Gear
babikov
Is there a detailed description or video for removing old bearings from the gear and pressing in the new once? I am talking about those that go onto the yoke. How far to press? How hard? Will the standard tool like this (https://www.youtube.com/watch?v=1vWeSAQERqU) work? Or I just use the hummer? The outdrive is Alpha One Gen II. Thanks.
dubs283
Yes, that tool will work for separating some bearings.
Which bearings are you referring to? Upper? Lower? There a few inside a Gen II drive and they require different processes for removing.
Do you have a manual? Merc #14 is the correct manual for a Gen II
gm280
Have a look here for removal and replace
https://www.youtube.com/watch?v=D1UVFlXd-aQ
Another method to remove, but I wouldn't do it this way unless the bearing cage was already broke
https://www.youtube.com/watch?v=bZH3d8fBrOg
I agree AllDodge, I would never try to do what the second video suggested. WHY? He had the bearing puller there. Why not just use it and save the bearing and fingers as well? :noidea:
And some people wonder why the get hurt in the shop. SMH!
babikov
Thanks for all responses. ​I am talking about this very assembly that Chris is setting the preload for, in this video: https://www.youtube.com/watch?v=lPr4UQPMBXg
But before putting it in, I have to replace the bearing assembly. Yes, I have the right manual, but there is not much detail.
The first video uses a good size press. My main question: is that size really needed? Will it be that difficult, or a small hand operated set (shown in the next video) will do the job (will be sufficient)?
Please, advise. Thanks.
alldodge
You can use a 2 jar puller similar to this one. Pay no attention to the socket and breaker bar
Now to put them back together, you need something with enough force to do it. A large bench vise, arbor press, or other. The issue is you need enough force with also enough room to be able to do it
You could also take it to a machine shop and they could do it for about $20
Bt Doctur
GEN II uses rolling torque on the yoke gearing . You just dont press it into position .
