problem with ordering parts
RobertThoreson
Ok when I go to the iboats parts page, it gives me 3 options, search for motor, browse by hp or browse by year. I have a 58 fastwin. If I go by hp, it don't go back to 58 same with by year and if I search for fastwin, nothing
GA_Boater
What parts are you looking for? You might have to look at the aftermarket parts like Sierra or CDI.
RobertThoreson
Well... j was looking to see what there was on the page here b4 I look elsewhere. I would like to overhaul the carb, new pump housing bc mine is original, lower unit gaskets, spare prop, plus see what other parts are available bc I have all winter to tinker with this thing
RobertThoreson
The coils are brand new. Plus I would like a manual so I don't have to do all the figuring out myself lol
GA_Boater
Appreciate you looking here first. I have asked the store support to look into this.
It seems you are looking at OEM parts and the year you need is not covered. Many aftermarket parts go way back. Which Fastwin do you have? 18 HP from your other posts, but what is the model number?
This may be your carb kit - http://www.iboats.com/Boat-Parts-Acc...62905&q=382049
This is a parts diagram for your lower unit with pump housing and seal/gaskets. It says for 20 HP motors, but it uses the same part. http://www.iboats.com/Gearcase-Group/dm/cart_id.632066984--session_id.984887016--view_id.1532542
Try our prop finder - http://boatpropellers.iboats.com/
