Storing outboard on the skeg
speo
Is it OK to store an outboard resting on the skeg, almost vertically? It is strapped to a solid shelf, leaning against the shelf and the wall, but most of the weight is on the skeg. Is that OK? The outboard is 180lb, 25HP.
jerryjerry05
It shouldn't bend.
​I found that if you can't put it on a rack or a permanent bracket.
I wrap the cover in foam and stand it on it's head.
Most of the weight is in the powerhead.
​They used to ship them either laying down or upside down.
​Being top heavy they don't fall over as easy.
gm280
It will be fine without any issues. The skeg takes a lot more abuse then the simple wight of the engine itself. JMHO
Gee, strap a couple of 2X6s together and spread the weight of the engine to the skeg and gearcase bottom.
Jeepster04
We have a couple old Volvo DP outdrives that I kept as spares.. Picked them up and slammed them down into the dirt... I imagine they'll be fine for many years. :)
bruceb58
OP hasn't been back since he posted this back in October.
speo
In the end, I bolted a couple of 2x4 to a strong shelf and just hanged the outboard on them like on a transom.
