- Jul 23, 2011
- 52,646
Having been a member on this wonderful forum for a few years, I thought I would share some perspectives
Design Life..... that magic duration of time that your product is designed to survive until being replaced.
Lawn and Garden equipment has a design life of about 7 years for the average consumer. Commercial lawn and garden equipment has a design life of 5 years with a major overhaul and re-power at 2-1/2 years
your average automobile has a design life of 180,000 miles (300,000 km's) or about 15 years with proper maintenance
our boats..... depending on manufacturer, about 10-15 years depending on manufacture (yes some have longer design lives). I am not talking large 40meter and 50 meter yachts which have a design life of 20-25 years between major refurbs or mega yachts with a 75 year design life, I am talking your average 21 foot run-about or 24' cuddy (express cruisers are about 15-20 years)
over 70% of the average new boat owners will resell the boat for a new boat. that number was in the 40% range in the 60's and the 60% range in the 90's the average boat is intended to be maintained on a regular basis and used on average about 50-100 hours per year the need to continue selling new boats will always prevent the market from building a "forever" boat. if such a boat could be built, it would be outside the realm of the average "Joe" and it would push the boating hobby to the uber rich only, and after a few years, the style would be out of date.
at the end of the design life, the mechanical systems will need serious attention, the trim within the vessel will need to be replaced, and all the soft surfaces should be replaced. if the boat has been maintained, the structure may be intact. The wood structure under many boats is slowly being replaced, not for longevity of the boat, however because it quickens up the boat building process. stinger tubs pulled out of a mold, slathered with adhesive from a pneumatic gun to glue the parts together is actually faster than a team of carpenters using machine cut plywood and stapling it in place for the guys to drape and bag resin soaked cloth . However the capitol required to invest into permanent molds pushes the building technique to some of the bigger names, or higher priced names.
Some of you may be thinking....if it doesnt have wood, it will last forever because it wont rot....true to some extent, however the boat still has a finite design life
just because a boat is "wood free" doesn't mean its problem free. adhesives put together in haste can have a curing or bonding issue. the adhesive bond has a minimum gap and a maximum gap to work within. work outside that window and the joint can fail. Adhesive joints can only flex so many times prior to parent material or the adhesive material failing from fatigue. exposure of flotation foam to moisture and freeze/thaw cycles can damage a boat. Back to the design life of the boat in the 10-15 year range. This is because the boat may not have wood to rot, it does have a one-time build hull that will eventually fatigue and fail at its flexure points
Add rough water, impacts to objects such as a beach, a trailer, another boat, or projectiles from a storm and the life of a particular boat is altered
Just getting to the desire of boat owners over the years add things to their boat to personalize them. flag poles, drink holders, rod holders, spare batteries, etc. all are screwed into the boat somewhere. in many instances the fastener will breach the method of encapsulation on wood structured boats or engineered structured boats. the flotation foam is then exposed and starts to deteriorate This also impacts the life of the boat
There is not much information on the web for design life, infact I found this by accident http://www.proglassinc.com/assets/boat.pdf which triggered a chain of thoughts stemming from design life conversations on other equipment at work the other day.
To that end, I thought I would post this here for those people that question why a boat manufacturer 30 years ago used wood or stables to hold the wood together.....and not make it "wood free". or why cant boats last 50+ years with neglect such as leaving the plug in the boat while the boat is exposed to dropping leaves, sun, rodents, etc.
its about the design life of the boat. its about getting a boat out the door at the lowest possible cost to the consumer while making the maximum profit for the manufacturer. This is done by not over-building boats as the manufacturer would be out of business as the demand drops when the market is saturated..... and not under-building boats as the warranty exposure would decimate the company..... however by building boats to a design life, where the boat makes it thru the warranty period, a few years past it to be sold and replaced, or mother nature drops a tree on it and its replaced
we here on iboats tend to be similar to the folks that sink $25,000 into a 1950 pickup truck. A new 2017 pickup truck would be 10,000 times better in ride quality, NVH quality, fuel economy, etc. however not everyone can afford a $55,000 truck and that 1950's truck is just cool
We do it because we enjoy the hobby of boating. we do it because our specific situation in life may preclude us from buying a new boat every 7-10 years. we rebuild motors, replace or rebuild outdrives, replace interiors, restore the hulls and structure. WE ALL complain that the boat should have been built better and built to last forever. the truth of the mater is that if the boat was built better and to last forever, most of us would not be boating, we would be rowing a $15,000 row boat or paddling a $10,000 canoe.
Instead we buy $10k or $20k used boats, we use them for a while, we then sell them and upgrade. or we buy a $5k project boat, completely strip it down to just the hull and build it up from there. We do it for the love of working on the boat, for the boat hobby itself. We do it to complain about things that we know in our heart we should not complain about. We do it because we love fishing or water sports or simply going for a cruise up the river/lake/ocean. Some of us do it because of nostalgia, some of us do it because we can build what we want when we cant buy it.
Happy Boating and remember, nearly all of us own a boat, car, lawnmower, etc. that is past its design life.
