Intruder 4.3
Thread starter- Joined
- Nov 29, 2010
- 19
2004 Mercruiser 4.3 MPI Alpha 1 drive Engine serial number OWOO7177 - model -MCM4.3L MPI
Drive serial number OL9566Z3
- Last couple of times out I have had the alarm go off for over heating (above ~200 degrees). This is a closed system with the through hull intake. Seems to over heat under a greater load. When I turn the motor off and restart the temp seems to drop as if the thermostat is intermittently sticking. The temperature range I am seeing is anywhere from 160-200+ which seems to wide. Last season I replaced the fresh water pump and thermostat so I am relatively sure this is not an impeller issue. My first thought is to replace the thermostat, as it is a cheap fix. I assume this a 160 degree Thermostat? Do thermostats fail intermittently? Any other suggestions on what could be causing?
