Queston about charging trolling motor batteries in parallel
bruceb58
Silvertip, I absolutely 100% agree with your assumption as well. However, what happens if just one cell in just one of the parallel batteries is shorted.
That's true...they don't. When that happens you deal with it and remove the bad battery. This is done with solar battery banks all the time. Also RV.
frantically relaxing
A 20 amp (for example) 2 bank charger doesn't have 2 separate 10 amp chargers built in, it's ONE 20 amp charger with 2 separate outputs. So there's always a full 20 amps available on either side of the charger. Example, you drive out into the lake a half mile, anchor up and run your 2 aux batteries dead playing the stereo all day. The half mile ride back won't charge the 2 dead batteries, but the start battery will be full-up. When you connect your 2-bank charger to these 2 banks of batteries, about 19 amps of the charger will be charging the dead batteries while 1 amp will trickle charging the start battery.
Same applies with charging the OP's 2 batteries, it's completely pointless to go to the trouble of disconnecting 2 batteries just to connect 2 separate charging cables from the same charger that has the same net output.
As for "what if one battery is shorted", it's entirely likely you'll know this before ever turning on the charger because both batteries will be dead. Fastest way to figure out which one IS dead is to charge both at once for about 10 minutes. Disconnect them from each other and check the voltage of each, the good battery will have lots more voltage than the bad one. Replace it and go boating! :)
bruceb58
That is not true. They are two separate chargers. This is actually demonstrated by the fact that the grounds are independent which allows you to use the two banks to charge 2 batteries WHILE the two are wired in series.
All chargers are different. Some will have one power supply that feeds two charging circuits which then distribute the charge or each will have its own dedicated supply.
Both of the chargers I own are the types that each bank are completely separate. One is a Guest and one is a DuoPro
