burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
This past weekend, I fell victim to the dreaded plastic pulley breakage on our 97 5.7. We were cruising at around 2900 rpms, when my wife said she "heard something" and the steering all of a sudden got tougher to turn. I cut power and shut her down within 10-15 seconds of this all occuring. I opened up the hatch and all that was left of the pulley was what you see in the photo.
I don't believe any other damage occurred, the temp gauge never much higher than normal, certainly not into overheat range. I didn't smell any burning rubber smell. To me it looks like Merc issued a recall on these pulleys but that has long since expired. So I understand that the 4.75" plastic is to be replaced with a 5.75" metal pulley and new serpentine belt. The current pump seems to spin freely and the belt looks fine overall, so I don't suspect any other accessories had seized that caused this.....A little disappointing that our day was cut short over a stupid plastic pulley
I can pull apart my boat to get access to the front of the pump, however, I am wondering if it would just be easier to remove the pump and do all the work out of the boat? I do understand that I need a pulley puller. What about putting it back on? A vice or press?
Or another thought, since the pump is well near 20 years old, should I find an OEM retrofit and replace the entire pump and pulley?
My only concern with unhooking the pump is bleeding/introducing air into the lines. I know how to bleed brakes but not a power steering system.
I would appreciate any input or any advice anyone has on this!
http://i1053.photobucket.com/albums/s471/burtonrider11/IMG_3833_zpsvqo1iww7.jpg
