1975 Evinrude 40 hp
mayns22
I also just remembered I hooked up a completely different gas tank with fresh fuel in it and still runs the same. Pulled the drain plug on the bowl numerous times and no water.
mayns22
I don't know why my comments keep disappearing on here but I tested spark with a spark tester and tested compression with a compression guage. 120 psi compression. The arcing I am here is the long arcing between the wire and the plug when I take the wire off the plug while its running.
oldboat1
There is only one fuel pump and all is good with that. Took it off and squeezed the bulb as instructed and all good. Diaphram is in good shape. I'm at a loss lol.
I wonder if you physically inspected the pump diaphragm -- needs to be a flat piece, completely flexible with no tears or pinholes. If it's stiff or misshapen it needs to be replaced, even if it seems to be complete. (possible rebuild kit: http://www.iboats.com/Evinrude-Fuel...4508162--session_id.571303580--view_id.269769)
mayns22
I did sir, but if that were bad wouldn't it affect both cylinders instead of just one?
gm280
If the diaphragm does have a pin hole in it, it would allow fuel to get inside. And depending where the pin hole is and the mounting position of the pump on the engine casing, it could effect one cylinder more then the other. So I would certainly check it out and even buy a rebuilt kit and install. The kit is cheap and easy to install. JMHO!
oldboat1
^^gm280 says it well. Will add that symptoms can be kind of quirky, in my experience. The last two or three I did had brittle diaphragms -- had not completely failed, but motor was stumbling, sometimes some smoke, then would pick up and run normally for a bit. (In my case, the lower cylinder seemed to be loading up.) Makes it a little hard to diagnose, but kits are cheap fixes.
mayns22
Brand new fuel pump and no change at all to the way it runs. Top cylinder is still flooding horribly. Does this engine have reed valves and if so could that be the problem?
gm280
What are the chances them are my problem?
Who knows until you check them out. If any are bent to where they won't close, or even cracked or broken. then you will need to replace them. But if they actually look okay, that isn't your problem. So check them out and see. Post a picture of them.
mayns22
All the parts I find none of them actually say "reed valve". What I'm guessing they are they are described as "leaf valve". Are them the correct parts?
mayns22
Figured so but had to be sure before I hit the order button. I thank you very much! I will be updating as I progress with this project.
