Caseyshoe27
Thread starter- Joined
- Jul 30, 2015
- 5
I have a 1990 Johnson GT 150. I have had it 5 years and has been running perfectly I always mix my oil directly 50:1 and never had a problem. Fast forward to about a month ago It cranks and idles perfectly on the hose or in a barrel. You can rev it up when you take it out of gear and its responsive. As soon as you put it in the water I can crank it and idle out and get ready for WOT and as soon as you hammer down it bogs down and dies. I can baby it and ease on the throttle and eventually get it to plane out and run WOT as long as I want but when I stop and try to plane again it bogs and dies.
I took it to a reputable mechanic and he replaced the stator, rebuilt carbs(had a few leaks), replaced all the gas lines and primer bulb. He said the power packs were good. I put a diaphragm kit in the VRO fuel pump ( Had a slight tear in a seal) that didn't fix it so that's when I decided to take it. I did notice the spark plugs were oil soaked so I replaced them as well.
I took it back this morning and he seemed kind of stumped.... And so am I. Im just running out of options Im beginning to worry its going to be something serious internal wise and cost me another arm and a leg I just spent around a grand like it is and its still not up to par.... He said he was going to do a compression test and pull the heads off and look inside. ANY IDEAS OR SUGGESTIONS? Thanks in advance!
