SeaEsta-12
Thread starter- Joined
- May 25, 2012
- 109
Ok, so their are zero mods to my engine. All stock engine and outdrive. (GM 5.7L GXi-A with a VP duo prop F4 blades)
I took the boat out today and could only reach 4000 RPMs. At that range I was getting 32 mph.
My specs say I should get 41 - 43 at 5000 RPMs. I can't even get my motor to go that high.
I just had the trottle cable replaced and I had them check the throttle range and he said it was a to spec. No play at all especially with the new cable.
What else could it be that I am not reaching my proper RPMs?
Thank you for all your help!
Side note:
Trim and trim tabs were all adjusted during my run.
I had a full tank of fuel and one passenger on board. Maybe at most I was at 7000 pounds.
Side note:
