Tony T.
Thread starter- Joined
- Jun 5, 2007
- 178
I have a 54lb thrust Motor Guide trolling motor hand operated on my Tracker boat, 3 weeks ago I was using it and on #5 max output setting the fuse blows leaving me with a dead trolling motor. The fuse was a older inline glass style fuse 30 amp and I was not able to pull it out, like it was corroded into the holder, I thought there's the problem. I replaced it with a inline blade style 30 amp fuse and the same thing happen today #5 max output setting fuse blows. Is a 30 amp the right fuse for a 54 lb thrust motor or do I need to go larger amp fuse ? I bought the boat used and the trolling motor came with it so I did not get a owners manual with the trolling motor.
Thanks for any info
Tony
Thanks for any info
Tony
