I have been wrestling with my 2002 Johnson 175 for a few weeks now.
I have been thru all of the diagnostic procedures.
My symptoms are the boat runs good at idle and mid-range but starves for fuel at higher RPM's and WOT.
If I pump the primer bulb all symptoms clear up until it uses all the primer pumped fuel again.
then after a few minutes the engine begins to misfire again due to lack of fuel.
I have decarbed the engine.
I have replaced the fuel filter.
I have inspected or replaced most of the fuel hoses associated with the VRO and fuel supply.
I have inspected the pulse limiter and checked for blockage in crank case where limiter attaches.
I have eliminated the existing fuel line to the tank and ran a new line from a remote tank with a new primer bulb.
I have rebuilt the VRO with the OMC kits.
I just completed a compression test and the results are as follows: 1- 104, 2- 105, 3- 105, 4- 104, 5- 102, 6- 95.
I know from doing the research that cyl #6 is the cyl that sends the pulse to the VRO for operation of the air pump diaphragm in the VRO.
Is it possible that 95 lbs of compression in # 6 is not enough to run the VRO efficiently?
Or should I replace the VRO with a new one?
Thanks in advance for any input or assistance.
Fish On!!
hazzman
Fish On!!
hazzman
