Tachometer Gauge Fix
mnjeepmale
When my motor is running the tachometer at times can go way up then back down and gives false readings. Is there a sensor I can replace to fix this on the engine?
5.0GL
Ayuh,.... Welcome Aboard,..... Odds are it's the tach itself that's dyin',...
It get's it's signal from the coil's (-) terminal, no sensor,...
mnjeepmale
So you think the gauge is dying and needs replaced?
How to fix a bad tach.... Remove old tach, but new tach, instal tach
muc
A lot of times you can get another year or two out of them by using a very small screw driver to move the cylinder selector switch on the back of the tach. Gently rotate the switch back and forth and then set it back to its original setting.
jerryjerry05
The tach replacement can fix the problem.
​Cleaning all the connectors between the motor and the tach can also help.
Spray the connectors with WD and plug and unplug them.
bnicov
Who is the manufacturer?? I know Faria has a lifetime warranty. You contact them and send it in. Ypu need to pay a fee which covers their shipping you a new or rebuilt guage.
