pressure test
flattop1
Is it possible to pressure test the crank case assembly?
I have replaced my check valves, rebuilt carbs, tested compression, timing and link and sync Still have an eratic idle seems to hunt a bit to much andthen die off.
Would a bad lower crank seal cause this?
Thanks for any help.
1985 90 hp evinrude
emdsapmgr
How does the compression on the bottom cylinder compare to the other three?
flattop1
checked plugs both bottom plugs are a bit dirty vs top 2 which look good.
currently on the lake so no gauge., with me.
How do you plug exhaust for pressure test? removing engine from lower unit to make a block off plate seems counter productive.
flattop1
Went to Ql78 plugs color cleaned up compression is 123-129 with bottom cylinder being 126.
engine died when loading on to trailer and when i removed the plugs they seem to be wet.
Maybe the float is set a bit high.
How would I do a pressure test?
Thanks Tony
Ibl0wstuffup
Did you check compression with the engine warm? I had a v4 that passed cold but dropped to 70psi in one cylinder warm. It had a scratched cylinder.
??-----There are 4 seperate crankcases to pressure test.-----You can use the bypass covers to find compression in them.-----No need to blank off the exhaust.-----So a bypass cover can be adapted with a gauge and pull the motor over to compare pressures.---Test one at a time.
flattop1
checked compression cold. will re test .
I overlooked the fact all the cylinders were separated by the sealing rings . interesting ,what pressure would it show 3-4lbs?
What would be a test for the lower crank seal? manual has no indication of any test procedure.
???---Crankcase compression test on # 4 cylinder will also test the bottom seal.----Removing the bypass covers will allow you to inspect pistons / rings.--I recommend you do that.
Bosunsmate
Thanks Tony
Light that wetness with a lighter, if it doesnt burn its water.
If it burns check that your primer bulb holds firm with engine off and check your spark
flattop1
did not burn: dipped it in the weed wacker tank big difference.
I guess the heads need to come off. any way to guess which one ?
Thanks Yall
