Tach over 2000 rpm off??
Skyhead22
23 foot pontoon, mercruiser 3.0. 21 pitch Mirage prop. 35mph wot light load tach reads 2200 rpm. That would give me -67% prop slip.
Realistically I'm turning 4600 rpm or so.
Boat was bought brand new 4 years ago by my parenents. All this time he thought wot was 2200 rpm.
What's the deal?
first, check to see if the tach is set to 8 cylinders vs 4 cylinders
if it is set right, then test it against a diagnostic service tach
if it is really that far off and set right, buy a new tach.
Skyhead22
Would the tach typically have a switch on the back of it?
yes, over 90% of the tachs used have a switch on the back side. that way the boat builder just has a pile of tachs that are the same across many models and doesnt care what motor is connected to it until the tach is installed to the specific boat.
thumpar
I think everything is fine mechanic wise. Check the switch. Even if it is set to 4 switch it back and forth in case the connections are corroded inside. With your numbers and a 12% slip it comes back at about 4000rpm so the prop might be a little steep. You should be around 4600+.
johnkom
Anything I put into the calculator comes up "NAN." What does that mean??
JK
Skyhead22
It is around 4600. The drive ratio is 2.4
