Are phone GPS chips accurate for speed
Status
Not open for further replies.
R055
Hey guys, I was looking to get a GPS speed unit to add to my dash till I found out how expensive they are. I have my phone with navionics, is the GPS speed displayed on it accurate? Did most people use their phones when they wrote "my max speed xxmph verified by gps"?
dozerII
Yes they are very accurate, there are any number of free speedo apps available for your smart phone.
my phone GPS speed matches my dash GPS speed if that is what you are asking.
oldjeep
There are plenty of inexpensive Gps speedometers out there, but the phone works fine too.
roffey
Set your cruise in your vehicle and compare to the phone app
The speedometer in your car is not accurate, better than your boat but still not accurate. Tire size, ware and other factors will play a large factor. IMHO, use the GPS on your phone.
How fast you go on the water is measured by the smile on your face, smile-o-meter.
David Young
GPS is GPS. Phone, speedometer, Fishfinder, etc. They will all be accurate :)
southkogs
I would say my Garmin GPS is more accurate, but the Navionics on my iPhone is a pretty close second. Both are more accurate than the speedometer is (both car and boat).
roffey
I suspect your Garmin will be more accurate but the phone GPS will not be wrong. The speed on my boat is say 35.4 MPH and the Garmin will be 35.44?
southkogs
LOL ... I'm not even being that accurate. I forget the numbers, but I think the Garmin has a better satellite connection and receives more updated signals than the iPhone does. I would say you might even be right on how different they are, but I'm sure it's not much more than 1 or 1.5 MPH off. I know the Garmin can get me closer to a precise LAT/LONG spot than the iPhone ... but again: feet, not miles.
So, "yup," you're right.
SkaterRace
Master Chief Petty Officer
In the navonics app, where the heck is the speed? I have been using it for a bit and never came across it.
bruceb58
The GPS receiver itself is only calculating location...it doesn't calculate speed. The software in the device uses the location values over time to determine the speed so depends on how accurate the device is with its time base and how often it does the calculation. Close enough for boating though.
frantically relaxing
Any GPS SHOULD be accurate, but so should tire gauges. Pick up any 3 gauges and check your tires. Chances are you'll get 3 different readings ;)
dingbat
They advise 1-3% accuracy for the latest smart phones but they are now where as precise as my chart plotter readings.
roffey
I'm to go out on a limb here. I disagree, a tire gauge is mechanical and GPS is electronic... and if you disagree with me..... I'll take your work on it, LOL.
I am a IT person, nothing to do with mechanical or GPS....
roffey
This weekend I am going to go out on the water and will bring two phones, a blackberry, IPhone 6 and a tire gauge. I will do extensive study's on the water and bring back my finding. These are just some of the things I do for you Iboat people.
.. to let you know ahead of time I am sure the tire gauge will not be much use on the water but I want to be fair and do a complete study.
R055
Thanks guys, I'm going to get a windshield mount and mount my phone with navionics so I can see more accurate speed and one of the lakes I go to have lots of twists and turns so I'll also use it for navigation while I'm still new to the lake.
In other news I fixed my boat speedo, the tube at the top of the lower unit on outdrive was disconnected.
R055
No Title
I've always had it since I got the app
Status
