Hi all,
As the title states, 1971 Johson 9.5hp. Low hours on this motor and very clean, I picked it up last year from a guy who said ever since he's owned it it's had a rough idle. He always just dealt with it. The spring of last year the carb was rebuilt.
My symptoms:
-Motor starts right up with easy pulls but must be opened up slightly to keep running. To shift into gear it must be quickly down throttled switched into gear, and then throttled up. I don't want to keep doing this because I know this is not good for the gears/clutch dog.
-Runs beautifully when given gas above idle, no sputtering, wide open throttle has great power (Got our 11 foot john boat up to 15mph)
-I have played with slow speed adjustment to no end. The knob also does not seem to impact the engine rpm whatsoever whether all the way in or backed way out. I'm thinking this may partly be where my problem is. If throttle is slightly open does this knob become irrelevant?
-Engine cover on/off also has no effect on idling performance.
-I replaced the upper crankshaft seal last year, problem did not change (No leaking fluid on seal but since flywheel was off I changed it anyway)
My thoughts are that, either I have an air leak somewhere or clog. I have a carb rebuild kit on the way and will start there. Going to pop some new spark plugs in as well because I don't know the last time they were changed. Does anyone have any other suggestions or experience they'd like to share? Is it possible my slow speed jet is clogged?
I'm a bit of an amateur so please excuse my ignorance. I plan on updating this thread until it is solved. I love this motor and really want it to be tip top.
Thanks,
Nate
My symptoms:
Thanks,
Nate
