Retrofitting from Alpha 1 to Bravo 1
tank1949
First, are the transom bolt patters the same? Or, will I have to fill in holes and redrill to use Bravo drives? Can I use existing couplers from Alphas? Will controls need to be changed/retried?
Ayuh,.... The transom holes are the same as the Alpha, Gen.II,....
Ya gotta drill 2 more holes at the top, if an Alpha 1,....
thumpar
If you are planning on using the same motor you will need to ditch the interrupt switch parts. If there is a computer it would be different for a Bravo also.
tank1949
For the Thunderbolt ignition System?????
Ayuh,..... All Mercruisers use T-Bolt ignition,... Bravos are wired differently than Alphas,....
