Stuck in forward gear - lower unit oil issue?
Schuppy
I recently started my 55HP Evinrude triumph and noticed that it wont leave forward gear. It is selectric shift, starting/running no trouble. Luckily it occurred while I was running with muffs on so I turned it off and did some googling to prevent causing further issues.
I noticed a few forums saying it could be water in the lower unit so I drained the oil and it was a milky colour so obviously water has found its way in.
I noticed that the washers looked quite old and worn so I'm going to buy some new ones today along with new oil and oil pump.
I also noticed a tiny crack on the lower unit with a little bit of what seems like engine oil not gear oil. I was planning on putting some epoxy on it to close it up incase it is gear oil. I know this is not the best way to close it up but I don't have access to any welding materials and I don't have the money to get it professionally fixed.
This motor runs in freshwater so hopefully corrosion has not occurred since I've acted pretty quick.
Just looking for any advice from someone who has had this issue? I don't want to make a mistake and cause futher issues.
Often the prop will spin in nuetral.---Start motor and use a stick to try and stop the prop.
jimmbo
Where is this 'tiny' crack? Pictures can be worth a thousand words. You should get the unit pressure and vacuum tested. Fresh oil and new gaskets for the fill and vent plugs may solve it. However, Water can, and usually does, get in thru other seals. You may or may not be aware your engine shifts into neutral and reverse using oil pressure, so it needs to be running. It will default to forward if, the oil pump fails, the solenoids controlling the oil flow fail, or the solenoids power supply fails.
I normally use my work boots to check.----A stick is very safe !!
Schuppy
Just got some new oil and washers. It is definitely in forward haha.
Will give an update soon.
F_R
They default to forward gear. Everything must be working for it to shift to any other gear. That includes electrical, hydraulic, and mechanical problems. Changing the oil is a good place to start, but beyond that you must do an orderly troubleshooting. Just guessing and replacing is an expensive way to go about it.
Schuppy
Hey Guys,
So I dropped the oil which had water in it. replaced it and ran it for a while then dropped the oil again and found it had water in it
but no where near as much so I will continue to wash it out this way until it is water free!.
Thanks for the help!
Tim Frank
Hey Guys,
A much better idea would be to re-read post #8. "When E.F.Hutton talks, everybody listens."....when FR writes, even E.F. Hutton reads. :)
You are still getting water....so you have a leak....so it needs to be fixed. Simple.
Changing the oil repeatedly will only benefit the oil industry, it won't solve your problem.
oldboat1
Very easy to rig up a down and dirty pressure tester, and test the l.u. -- locate the leak and fix it. I use a bicycle style foot pump that has a gauge. Put the inflation needle through some kind of rubber fitting or gasket that you can hold in place to seal. Remove the l.u., and test the empty gearcase under water, vent and drain plugs installed (watch for bubbles at the leak). Only about 8 lbs pressure.
