I recently started my 55HP Evinrude triumph and noticed that it wont leave forward gear. It is selectric shift, starting/running no trouble. Luckily it occurred while I was running with muffs on so I turned it off and did some googling to prevent causing further issues.
I noticed a few forums saying it could be water in the lower unit so I drained the oil and it was a milky colour so obviously water has found its way in.
I noticed that the washers looked quite old and worn so I'm going to buy some new ones today along with new oil and oil pump.
I also noticed a tiny crack on the lower unit with a little bit of what seems like engine oil not gear oil. I was planning on putting some epoxy on it to close it up incase it is gear oil. I know this is not the best way to close it up but I don't have access to any welding materials and I don't have the money to get it professionally fixed.
This motor runs in freshwater so hopefully corrosion has not occurred since I've acted pretty quick.
Just looking for any advice from someone who has had this issue? I don't want to make a mistake and cause futher issues.
