I have a 1994 30 hp Evinrude E30ELERM. The flywheel has a couple of bad teeth causing the starter to "hang up" every once in a while. I want to replace the flywheel but have run into the following issue. :
The Evinrude OEM # is 0584373 which was superseded by a 0585158 which was again superseded by a 0583001.
The flywheel I took off the motor is a 513863.......very confusing.
Can someone shed some light on this ?? What number should I look for ?? And even though a 0583001 does not look like the flywheel I removed will it work ???
Thanks for any help I can get . LOL
