findinghomer
- Nov 7, 2009
- 359
Hi guys, I recently removed my engine. To do so, I loosened my exhaust elbows from the 3-inch Riser block ( not from the manifold) to lift up an inch or so so I can get the rubber hoses off. I could not completely remove the elbow because of my engine bay clearance. I removed it enough to give me some room to wiggle the rubber hoses off. I got everything back together, and now I have one side running hotter than the other ( engine is not overheating, and the drive is a brand new assembly so the impeller is good) So I want to take the elbow off and inspect everything, like I should have done with the engine out but I didn't know any better. But after doing a lot of reading it sounds like that's what I need to do. Now that I understand exhaust risers and manifold much more, now I'm worried that when I removed that elbow from the Riser block, I may have damaged the gasket. If I did so with that allow water to get into my engine? Any rate I need to remove the elbow. But just like before I cannot do that because of my engine bay clearance. I would have to remove all for studs and remove the elbow and 3 inch Riser block from the manifold in order to do so. How do I go about this? My setup, is an exhaust elbow and riser block being held together with four lag studs and then a nut on top. Any input or tips are welcome, I appreciate it thank you
