LED lighting
chadyboy
I have an LED project that I am working on. I will be installing the 5050 led light strip in my boat. My question is, how do I connect the power supply of this LED light to the "AUX" switch on my boats console? the LED kit includes a wall plug, but obviously the boat does not have this. Whats the best way to connect to this switch?
GA_Boater
Wall plug? It sounds like you have AC LEDs instead of DC LEDS.
bruceb58
The power supply likely has a 12V DC output. You don't use the power supply on your boat.
Have pictures or a link to what you bought?
64osby
Find a plug/cord that matches the power input to the white box. Connect that to your switch.
You wouldn't need to cut any wires doing that. You might be able to use the power source for something else.
If you can't find a plug, cut the wire.
bruceb58
Yep, should be easy finding a power plug to match.
JoshOnt
I bought similar lights but have yet to figure out how to connect them as well hopefully someone has an idea/ link to something that can help.
chadyboy
I assume when I cut the wire, there is a black / red wire? Then just connect to the switch?
GA_Boater
If you're like me, you probably have a 12 V charger for old cell phones or another device with a matching plug. I have a box full in case I need a charger for something. Cut the plug end off and wire it the battery or other 12V source.
chadyboy
I want to make sure I am understanding correctly. Find a black cable that matches the input of the power supply, and cut off the wall plug part. Then plug the end part into the white box, the other splice and hook up to the console switch?
gm280
Okay not being able to actually see the power supply output, you could have an issue. Yes that is a 12 power supply but is it an AC supply or DC supply? If the power supply is merely a 120VAC reduced to 12VAC, then not all your LEDs are going to light. So even with the proper attachment cord and wired into the panel switch, you may not get all the LEDs to come on. It really depends on the type power supply they went with. If it is an AC output, then alternately the LEDs will light during their part of the AC cycle. But since it would happen so fast, it would look like all of them are lite at the same time. So applying a 12 DC voltage to them, only half will light. Really depends on how there are wired from the factory. Just saying! JMHO!
JoshOnt
The lights are DC 12v because the power adapter turns it from AC to DC power far as I can tell. Thing is only 3 bucks so worth a shot.
gm280
I tried to see it but I could tell if it was 12 AC or 12 DC. So I just was offering a heads up.
JoshOnt
Here are the exact lights I have [first link], below there is an adapter [second link] which says output is 12 V DC so seeing as the suggest that adapter it should work. We will see in a few weeks time when the part comes in, might have to order a second if it works since I figure I might need some more lights.
https://www.amazon.ca/dp/B00HSF65MC...UTF8&colid=2WOG3KJ4ZUE26&coliid=IWKSTP1V8JWFL
https://www.amazon.ca/Lighting-EVER...bxgy_23_2?ie=UTF8&refRID=G825KSA7CW98SNDD4Q89
gm280
Sound like you are in good then . :thumb:
bwraven
Those really aren't designed for a boat. The SMD LED's are mounted to the strip in a way that makes them waterproof, until it degrades. The rest of the unit is not waterproof. It will corrode.
Are you wanting to use these to "look cool" or for actual useful lighting. Being RGB (red-green-blue) LED's, they won't be much use for other than mood lighting.
Iboats sells LED strip lights and that's paying for this free forum.
They can be wired directly to your switch.
bruceb58
This is what I did in my boat. I used blue LED waterproof strips in a housing. I really wouldn't want any other color:
