burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
Hi guys, looking to swap my ignition coil this spring to one of the PerTronix Flamethrowers, most likely 45011. My engine serial number is 0K010675, 5.7l 2bbl Merc. TB4 ignition. I have identified the coil as original part number 392-7803A4 later referred to as 805570A2. In the research I did, it looks like this coil does NOT use an external resistor. However, it looks like I have a purple wire that goes to my existing coil. Is this a "resistance wire" and does it need to be replaced with a normal stranded wire to eliminate the resistance. I read that it looks like I can replace this wire with a new one coming from the choke. Not a big deal if I need to do so, just want to confirm prior to doing so. Any info would be greatly appreciated!
