Woodonglass
- Dec 29, 2009
- 25,932
Soooo the tech at the glass store said it was OK to lay down woven fabric without a layer of CSM first??? How old was this guy? Did he know you were using Polyester Resin? He was probably thinking about epoxy which doesn't require it. The short semi - technical explanation is...Polyester resin becomes very hard and brittle when it cures. Epoxy remains somewhat soft and flexible when it cures. The CSM fibers due to a chemical reaction with the resin will melt into the resin mix and like "Rebar and Concrete" hold everything togehter so when it flexes it won't break? This helps create a very strong bond between the wood and the woven roving. If you don't use the CSM when the boat flexes the Resin will break and Crack and cause all kinds of problems.
