1972 merc 110 9.8hp thunderbolt ignition
  • poll error
    Votes: 1 100.0%
  • poll error
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Cant seem to figure out the kill switch on this motor and tried looking every where to figure it out. If anyone has this motor could you please take a picture of the switch and where it goes im at a lost.
roscoe
Hi, welcome to iboats.
Are you trying to wire in a new kill switch?
Need to know where to connect the wires?
tpenfield
It *should* be on the faceplate where the fuel line attaches. If it is not there, then chances are it has been 'modified'. You can see parts diagrams on the marine engine . com site
countryboy26047
Actually have the same exact motor (year and all) as a kicker on my tracker Pro V... I'll try and get a picture of the setup this afternoon once the temp's go above freezing-my-bearings off! lol
flyingscott
There is only one wire on the kill switch it has the phasemaker ignition. Kind of a backwards set-up It actually works by stopping the ignition from going to ground which causes problems when you kill it on the muffs. Leave it off and use the choke to kill it or try to get the idle down low enough so it dies.
countryboy26047
Not sure if this was a conversion year but my 110 has the thunderbolt ignition.... 99% sure it's a '72 but there's a chance it could be a '73....
flyingscott
Thunderbolt was a general name for the mercurys ignition system that covered many years and styles. The phasemaker is a thunderbolt ignition that I believe is on the 7.5/9.8 blocks from 1968-1972. You need to be careful with that ignition because the stators are expensive and easily damaged. What color stripe is on the motor blue should be a CDI ignition red is the phasemaker. Easy to tell when you are looking at the front of the motor with the wrap off look at the left side of the motor if you have a switchbox/cdi there 73 or newer. I have a free 1971 20 hp that lost spark because the guy kept hitting the kill switch on the muffs now it needs a new stator
countryboy26047
Ahh, ya learn something new every day! Thanks for that information, I always assumed the Thunderbolt was it's own component not a general term for multiple.... As far as my 110 goes, it's a blue stripe so that would be CDI I guess?
if its a CDI, connect a momentary switch between the isolated terminal under the flywheel (accessed from the side near the starter boss) and ground.
flyingscott
Probably a cdi look on the side of the like i said or put the serial # up to make sure because the wraps can be changed easily.
The serial number on my motor is 2846261 but everytime i try to look up a parts says serial number not found and i have red sticker on it
flyingscott
The CDI box is the ignition pack should have wires from under the flywheel going to it and green wires to the coils coming out of it.
