Gentleman I sincerely appreciate all your helpful input.
I personally changed the water-pump on the 89 and I can report the the old one was not in pieces when I changed it. Everything went together with no fuss.
Faztbullet - When I mentioned normal flow out the idle relief ports, I meant it was normal (trickle at idle and increased flow with more throttle)
When I changed the thermostat and heat sensor in the 89, It showed no signs of blockage or build-up in the t-stat cavity.
The owner of the 95 model says the motor will run fine without the thermostat. Which leads me to think that there may be blockage somewhere else that is causing the motor to starve for cooling water, because the thermostat's mere presence in the cavity is restricting the flow enough to cause an overheat. The 95 owner did report that he noticed a build-up of sediment in and around the the T-stat cavity, so Logic tells me it has to be else-ware too.
I'll re-examine the telltale on the 89, but the OMC bulletin I obtained for the tell tale hose relocation says it applies to post '94 motors.
Its a odd thing guys, I've been around these great motors my whole life, and I even owned a couple of them, but I've never seen one act like this before.
