Seahawk170
Thread starter- Joined
- Jan 16, 2016
- 56
Hello, I'm a newbie here and would appreciate some advice from those that have successfully raised the transom on an aluminum runabout. I like to fish Puget Sound (saltwater), and during my 10 +/- trips last summer I hated seeing following waves occasionally splashing into my transom well. While at a marine store a few weeks ago I talked to a local machine shop owner who told me that he has raised well over 100 transoms over the years and was sure he could raise mine up to handle a 25" outboard. He mentioned a new aluminum plate fastened to outer transom with (3) 1/2"x1.75" alum.bars vertically welded to top of my notched transom, plus a new welded plate across the top with a new plate welded to it all on the motor well side. This machinist also said that he would need to physically see my boat for measurements, and perhaps a different method will be required.
My boat is a 2015 Riverhawk, Seahawk Sport 17' (Oregon made), and it currently has a 20" transom height where outboard mounts, 14 degree deadrise aft, sides of boat are 34",and bottom width is 66". The outboard sits in a notched transom (16" bottom to 26" top width at notch), and then the secondary top of transom is 5" taller. There is no wood in my transom, it's all aluminum, and according to spec. has a 0.160" transom skin, reinforced with semi-box beam aluminum struts vertically all welded.
Does the above method for raising the transom notch seem reasonable, and is there any major structural issues I should be aware of?
Last weekend I purchased a 2013 Yamaha 90hp engine with a 25" leg, but it's 381# weight has me very concerned about structurally getting this done properly.
All advice is greatly appreciated!!
Thanks,
Arne
Thanks,
Arne
