HIN Search results:
Success!?STR82708M74F is of the standard HIN type called Model-Year HIN. If you are buying this boat/craft then you should get the?boat history?and?Boat Insurance from the BoatU.S. Program.
STR HIN DecoderOur HULL ID Decoder breaks down the Hull identification number into the following information:
The HIN or CIN you have entered meets the Model-Year HIN format. It might also be a type that contains the country code and thus the boat comes from USA or Other . The serial number of the HIN is 82708 and is set by the boat builder. This boat or vessel has a Certification Date of (74) and a Model Year of 74 with month of build (January) based on the formatting of your hull_identification_number (HIN) .
The manufacturer identification code (MIC) of your craft identification number (CIN or HIN) is STR. This MIC (STR) stands for the company name Starcraft which is currently In Business. This boat manufacturer has other company names (STR sometimes goes by these name(s) Monark, Spectrum, Fisher, or Northwood.
This company (Starcraft) is owned by David Frey and is located at PO BOX 65 in NEW PARIS state of IN. It manufactured this vessel and placed you HIN or CIN on the hull. The Parent Company for this boat maker is SMOKER CRAFT, INC. (SMK). Starcraft has started making boats, yachts and other watercraft as of 06/04/1973 0:00.
Make sure to compare the date of boat manufacturing with the dates in which the company was actually in business.
The US Coast guard provides this comment about this watercraft manufacturer: See (dem) O'day Using This Code 86&87. See Xdy,ray,cab,sur Also Has Fmc From Fisher Marine, Building Utility, V-bottom Fishing (rivetted), Pontoons & Fiberglass Boats At This Location; See (bmd) (fmc) & (bff). Northwood Was Private Label Mfg 1991-1993. 970107 Starcraft No Longer Owned By Brunswick; Acquired By Employees. See Also (plx) & (mnx). Starcraft Marine Llc Produces Starcraft & Monark; Tracker Marine Produces Fisher & Spectrum. 04/28/2001 Updated Per Rni. Note: Starcraft Shares Some Resources With Smoker/sylvan (smk) & (syl). Str, Along With Mnk And Plx Merged With Smk On May 08. Also Changed Poc From Merle Graybill To David Frey. All Production Moved From Topeka To New Paris, In..
More details at the?US Coast Guard.
If you are purchasing this boat/hull then get the?Boat History here?or the?BoatFax Reportto complement it.
There are 7 boat Recalls for Starcraft your vessel:
Starcraft Boat Recalls for your HIN and MIC: 7.
1-starcraft Marine Has Recalled Str14595b808 (hin Or Cin) Due To Ventilation And And This Boat Recall Is Closed. It Applied To 104 Boats From The 2008 1900 Io Model Boats. The Boat Recalls Applied On 21/02/2008 And Was Closed On 16/09/2010 With The Following Comment: Natural Ventilation System Supply And Exhaust Openings Must Meet Minimum Aggregate Regulations. 4/16/08 Rec'd Dnr. 6/104 Corrected. 26/104 Corrected 9/18/2008. 34/104 Corrected 1/12/09. Cur Rec'd 3/23/09. 37/104 Corrected. Emailed Dave Frey And Left Vm On 8/18/09 Jdh Asking For Update Within One Week. Recd Cur 6 8/25/09 38/104 Corrected Next Cur Due 11/25/09 Jdh. Recd Cur 7 39/104 Corr 2/10/10, Next Cur 5/12/10 Jd. Emailed Mnf To Remind Him Abotu Cur Due Jdh 5/20/10. Cur 8 Recd. 38/104 Corr, Req One More Cur Jdh 6/2/10. Emailed Mnf 9/13/10 To Remind About Cur Jdh. Recd Cur 9, 9/16/10 Jdh- No Change, Mnf Requests Closure Again Due To No Change In Last Year. Campaign No Longer Monitored 9/16/10 Jdh Pre Plc.
2-starcraft Marine Llc Has Recalled (hin Or Cin) Due To Fuel Fill Fitting Cracks And Fuel Fill Fitting Cracks And This Boat Recall Is Closed. It Applied To 1501 Boats From The 1995 See File Model Boats. The Boat Recalls Applied On 13/09/1995 And Was Closed On 04/03/1999 With The Following Comment: Both Starcraft (str) And Fisher Marine (fmc).starcraft Stardeck 200 Dlx, 240 Dlx And 180, 1700, 1709, 1710, 1800ss, 1810, 1810ss, 1811, 2010. 2010ss, 2012, 2210ss, 2212, Starship 2000, Tp 160 T, Tp 160, Tp 170, Tp 180 . Fisher Marine Freedom 200 Dlx, 240 Dlx, 220 Fish, 260 Grande, Fr200s. Monark Sun Spa 200, 240, 260, Pro 1800, 1800dc, 1800fs. Spectrum 20 Cruiser Dlx, 24 Cruiser Dlx/ Cur 1 Rcvd 01 Feb 96. Cur 2, Cur 2 Rcvd 30 Apr 96, Cur 3 Rcvd 6 Aug 96 - Rjd 11/96 Rcvd Cur 4. 02/97 Rcvd Cur 5. 05/97 Cur 6 Rcvd. Cur 07 Rcvd 08/97, Cur 08 Rcvd 11/97, Cur 09 Rcvd. Cur 10 Rcvd 6/98, Cur 11 Rcvd 8/98, Cur 12 Rcvd 11/98 Closed
3-starcraft Marine Llc Has Recalled Str & Mnx (hin Or Cin) Due To Nav Light - Height And And This Boat Recall Is Closed. It Applied To 104 Boats From The 1999 Deckboat Model Boats. The Boat Recalls Applied On 17/02/1999 And Was Closed On 25/01/2001 With The Following Comment: 990224 Sent Forms. All-around White Not High Enough; Will Not Show 360 Deg With Canvas Top Up. 990325 Dnr Rcvd. 990607 Cur 1 Rcvd. 990908 Cur 2 Rcvd. 991208 Cur 3 Rcvd. 000307 Cur 4 Rcvd. 000619 Cur 5 Rcvd. 000914 Cur 6 Rcvd. 001207 Cur 7 Rcvd.
4-starcraft Marine Llc Has Recalled Stra25tah596 (hin Or Cin) Due To Safe Load: Max Wt And Safe Load: Pers And This Boat Recall Is Closed. It Applied To 50 Boats From The 1996 12 Sk Model Boats. The Boat Recalls Applied On 29/07/1997 And Was Closed On With The Following Comment:
5-starcraft Marine Has Recalled Str85114a505 (hin Or Cin) Due To Ventilation And Ventilation And This Boat Recall Is Closed. It Applied To 556 Boats From The 2005 Aurora 2000 Io Model Boats. The Boat Recalls Applied On 03/03/2005 And Was Closed On 24/10/2007 With The Following Comment: Dn Issue 1.the Natural Supply And Exhaust Ventilation Area Should Be A Minimum Of 12.96 Sq.in. Each. Two 3-inch Supply Openings And Two 3-inch Exhaust Hoses Were Installed For An Aggregate Supply Opening Of 14.2 Sq.in And An Aggregate Exhaust Opening Of 14.2 Sq.in. However, Decorative Grills Installed On Both The Supply And Exhaust Openings Reduced This Area From 14.2 Sq.in. To 8.3 Sq.in. Fp Issue 2. An Opening In The Bulkhead And Deck Located Between The Fuel Tankand Engine Compartments Exceeded 2% Of That Bulkhead And Deck Area. 050404 Assigned 050016s To Smokercraft Portion Of This Campaign. Rec'd Cur 344/556 Units Corrected. 10/24/07 Campaign Closed After No Progress For 6 Months.
6-starcraft Has Recalled (hin Or Cin) Due To Electrical Bonding Wire And At Fuel Fill And This Boat Recall Is Closed. It Applied To 451 Boats From The 1992 171, 171, 191, 211 Model Boats. The Boat Recalls Applied On 13/08/1992 And Was Closed On 22/11/1996 With The Following Comment: Risk Of Static Spark. Letter From Mfg 09/16/96. 450 Boats Identified. 407 First Purchasers Notified 113 Boats Found To Have The Defect 113 Corrected.
7-starcraft Marine Has Recalled Us-str98540b707 (hin Or Cin) Due To Ventilation And And This Boat Recall Is Closed. It Applied To 34 Boats From The 2007 Starstep 200 Inboard Deck Boat Model Boats. The Boat Recalls Applied On 05/03/2007 And Was Closed On 01/03/2010 With The Following Comment: The Engine Compartment Natural Supply And Exhaust Ventilation Openings Were Of Insufficient Size For The Compartment Net Volume. The Gasoline Engine Space Was Open To Additional Compartments Forward Of The Engine Space. The Total Net Compartment Volume Of Approximately 124 Cubic Feet Requires A Minimum Aggregate Cross-sectional Area Of 16.0 Square Inshes For Both Natural Supply And Natural Exhaust. Two 3-inch Supply Vents And Two 3-inch Exhaust Ducts Were Installed, Which Provided An Aggregate Opening Of 14.2 Sq Inches For The Supply And 14.2 Square Inches For The Exhaust. Hull Vent Covers Reduced The Aggregate Opening Area To 11.0 Square Inches For Both Supply And Exhaust. Rec'd Dnr 4-16-07. 3/34 Corrected. Next Cur Due 07-16-07. Emailed Dave Frey 8/18/09 Jdh Asking For Update Within A Week. Recd Cur 8/25/09 32/34 Corrected Jdh. Recommend Closure. Spoke To Plc Concernign Status Of Campaign Jdh 9/17/09. Emailed Plc 2/19/10 To See If Response Fell Through Cracks Jdh. Plc Reported Having Enought O Close Case But No Dnr On File. Emailed D Frey To See If He Had It And As Of 3/1/10 He Is Looking Jdh. Dave Frey Emailed Dnr, Closed Per Plc Recommendations Jdh 3/1/10.
