1973 18 HP Rubber Plugs
w2much
1973 18 HP Evinrude Rubber Plugs Midsection There are several rubber plugs on this engine midsection / exhaust housing then two on the lower unit.Curious what they are there for.
Without seeing a picture I would say they are on the grommet for the water tube that goes to the power head.------These " rubber plugs " keep the grommet in place.
Vic.S
Can you identify them on the parts diagrams
convert
convert
Item # 10 there is one shown in the water pump housing and there is one in the exhaust housing.------The one that goes in the exhaust housing does not appear to be shown.
F_R
That doesn't appear to be what w2much is asking. He said "several on the midsection and two on the lower unit". I have no clue. Except he may be seeing the tabs on the grommet where they show through the side. But that isn't "several".
w2much
There is one one the mid section and 1 or 2 on the l/u. None are shown on the parts diagrams. Lower unit is now outside in the dark submerged in greasy water or I could
tell you if there were 1 or 2 . There is an older post showing the one on the midsection.
w2much
There is a post from 69fastwin Sept 2015 which shows a good picture of the midsection. Halfway up or down the photo you will see what appears to be a round hole. In this hole on my engine is a rubber something or other. There is also one or 2 on the gearcase. Tried to upload photos but it did not work for me.
F_R
Haven't seen the picture, but I'm sure you are looking at the "tits" on the water tube grommets number 10 on the gearcase parts picture above. They hold the grommets in place.
oldboat1
Believe I found the thread: http://forums.iboats.com/forum/engin...win-water-hole
If referring to the drain holes, think there would also be a single one on the l.u. These should be open. (Folks usually complain that unburnt fuel and water is leaking -- what looks like gear oil to them -- so maybe somebody plugged yours for that reason.)
[ed.: btw -- if it is plugged weep/drain holes, you might want to try and pull out the blockages. Maybe it's RTV sealant or something you can get a grip on with a tiny screw.]
F_R
No Title
Borrowing the picture suggested by oldboat, here are the holes that MIGHT be in question:
oldboat1
kind of a mixed bag on the leg. may need a pic of your motor when you get to it -- would look for a weep hole in the l.u. too, but think location varies. On the l.u., there are sometimes corrosion issues creating drain holes that that weren't intended -- so could complicate things. Not so much with freshwater motors.
w2much
Thanks for reposting the picture. Thats what I was talking about. Will look at l/u tomorrow. Picked up a 15 hp johnson today. My next project.
