Alpha One Oil Sender
After hours of search could someone please help. I have a 1996 Ebbtide Mystique 1900 with 1995 GM 305 V-8 two barrel and need a replacement Mercruiser oil pressure sending unit. I have not been able to determine the CORRECT replacement unit needed. Any help is much appreciated. Thanks in advance.
Bt Doctur
Sierra Oil Pressure Sender 18-5899 this is for the oil pressure gauge
Grub54891
You local parts store would have it. It's just a gm sender. Nothing really marine about it.
Thanks so much. While on the topic of replacing parts would a GM coil from that same year be OK for my application? I will replace it while on that section of the engine. Again, thanks for your time and efforts.
No,.... GM don't use Mercruiser's T-Bolt ignition,.....
Why ya changin' the coil,..?? they very rarely go bad,....
Also, do you have suggestion for where to purchase? Again, thanks.
Ayuh,.... Right here at iboats of course,...
Fun Times
