burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
My starting saga continues....I went to winterize our boat this weekend and while trying to start it, after a few cranks, that starter starting making really bad sounds. I am thinking I may have a broken tooth on the flywheel/ring gear. I did note that my batteries were a bit low and I could not get the boat started after a few minutes of trying. I charged up a battery and poof, boat fired right up. This time, I didn't note any noises.
If I do have a broken tooth, can I continue using the flywheel as is, taking care not to crank it a lot? I know this will require pulling the engine, so I'd like to avoid the major mechanics bill for this....
Also, I do have a new marine starter installed, it has worked perfectly the last 3 times since I installed it, maybe there is something wrong there? I don't recall seeing a shim from the original starter I removed. I did check the starter, it didn't feel loose. Is it possible that it does need a shim?
I am wondering also, if it could be something with starter not having a full battery charge and disengaging with the flywheel? I noticed that after initial noise, the starter sounds different, almost like it's spinning faster?
I should also note that after the boat was started, it ran perfectly, so I don't suspect something internally wrong with the engine that is causing this.
As always, thanks for all the help here!
