3.0 Block identifying and swapping parts
fairshopperguy27
Trying to find out what year this engine is block#3915991 it came out of a 1989 but I suspect it may not be the original engine, the coupler is smoked, I removed it and it is not the modern triangle syle one its the other circluar kind with several bolt holes. I have a 1997 3.0lx cracked block # 14097080 and am wondering if I can just swap over the Flywheel, coupler and bellhousing? Also will swap the front motor mount if the rear is possible. Already swapped the electronic ignition which is working great. This will be going into a 1997 Bayliner Classic 1950.
Ayuh,.... The crankshaft bolt pattern changed in 1990, so the flywheel won't swap,....
If the flywheel has the clutch bolt holes, you can use the newer style coupler on it,....
fairshopperguy27
OK yes forgot about the crankshaft change. If i am able to use the 97' coupler will the gen 2 outdrive mate up without any issues?
fairshopperguy27
Thanks for your help. Where do I go to get year/model info by going off my block number 3915991?
Trying to figure out if I have 2.5 or 3.0 here. Thanks
thumpar
Does it have a pulley on the front of the crank or a harmonic balancer? The 2.5l was just a pulley the 3.0l was a harmonic balancer.
fairshopperguy27
No Title
Thanks I will check this out tonight. Here's a pic of the coupler I need to replace (the one off the motor) along with a pic of the 97' coupler I plan to swap in. Hopefully.
fairshopperguy27
No Title
It sure is a 2.5. Theres no issues with taking the electronic ignition off the 97' 3.0lx and running it on this older 2.5 right? Seems to run good. I timed it correctly in base mode.
Fun Times
The year of the engine looks to be in-between 1974 - 77 according to the serial number chart for the 4 cylinder engines. http://www.marineparts.com/partspage...elp/TECH16.HTM
Below should be some info that you may need to know for correct fitment. Be sure to read the notes for all of the engine couplers found in the links below to see if it may help any with your question using a visual for what you're working with keeping in mind the one and two piece rear main seals/year changes.
MerCruiser GM Engine Identification
http://bluewatermarinesvc.com/html/mercruiser_fyi.html
http://www.mercstuff.com/couplers.htm
http://bpi.ebasicpower.com/shop/inde..._964_1092_1104
fairshopperguy27
[url]http://www.boatfix.com/merc/bullet/95/95_05.PDFMerCruiser GM Engine Identification[/URL]
Thank you. Very good info. Case closed.
