Got a better look at it today. Here's what I learned:
- The Floor is solid. Did a little bounce step all over - its pretty sturdy.
- The red carpet has a fairly big stain in the middle of it between the two primary seats. I'd like to see about removing the stain.
-There are a couple of rips in the upholstery. A tiny one on the back over the engine. Smaller than a dime. There is a larger one in one of the front bow seats, Looks like either something chewed it or it ripped on something. It's right in the side where it meets the back cushion so it's not that noticeable, but I also don't want to leave it and have it get wet, so I'll need to patch these.
- Now that the boat is clean and dry, it's a lot nicer. Stringers are fiberglass wrapped and seem in good shape.
- Transom is solid.
- Outdrive is in excellent condition, and has a brand new prop and hydrofoil.
- The boat has trim levellers on the back as well.
- The 120HP Mercruiser fires right up now, no hesitation at all.
- Bilge pump is NOT working, but he's going to work it to get it fixed.
- Still checking all the gauges and switches to see if they all work or see what doesn't. It has an auto-bilge function that we're not sure if it works yet.
- I will want to paint it probably over the winter or in the spring before it goes in the water. Just needs a fresh coat.
- Front red/green lights work, haven't check rear white yet, but we'll get it working.
- It's a little light on storage. There is some under the front seats, the anchor is up there now. There is some in the back in compartments next to the engine, and a small pocket on the back of each of the two swivel seats. Also a small glovebox but no side pockets.
I think that's it for now. Looking good.
