Suzuki water pressure
buck1
Just had a Suzuki DF50 installed on pontoon boat. The water pressure gauge shows no pressure, even at wot. What should the pressure be? Thanks
Mas
Re: Suzuki water pressure
More importantly, what's the temp of the motor at WOT?
MAS
Silvertip
If the water pressure gauge is plumbed into the tell tale line, it will run 5 - 8 PSI at WOT and just a couple of PSI at idle. The relationship between water pressure and temperature is one-way. Just because you have water pressure does not mean the engine won't over heat. However if there is NO water pressure the engine will definitely overheat. Water pressure gauges merely indicate that the water pump is working. It is no guarantee the engine is cooling properly.
