1985 Johnson 100hp v4 model #J100WMLCOC questions
Bosunsmate
I'll do that when I get home today. That wouldn't cause it to run out of fuel would it? I've also heard that you have to keep your tank sealed in order for it to work properly. Doesn't make sense to me that creating a vacuum in the tank would help it draw fuel lol. Just thought I'd ask a 3rd opinion.
You are correct there, dont worry, you dont need to name names:bolt:
It might cause the other carb to run low on fuel
mikeypb86
My old hillbilly neighbor told me this lol. Well, I took off the carb that was overflowing, and somehow a small piece of debris got between the needle and seat and prevented it from closing. Got that cleared out. Now I'm convinced it's my vro fuel side for the fuel issues. I primed the system until the carbs were full then disconnected the output line and started it. No fuel. Checked my vacuum line and it was nice and snug (and brand new). Took it off and probed inside the port to the crank case to feel for stoppages, and it was clear. I want to do away with the vro since its pricey and I've been mixing my own fuel anyways. I know max rules has mechanical replacements but I feel I can get one cheaper locally (military discount haha). They just need a part number and they'll get me one. Max rules doesnt seem to have the part numbers to them or if they do I'm being blind. So, would anyone know how to acquire the part number for one that'll work?
mikeypb86
Got it running! I took the vro apart and I flipped the flat rubber flap around and I guess that did the trick! I started it and ran it for about 15 minutes. Also kicked the throttle a few times and it revved right up! The only thing is it don't like low idle.
mikeypb86
Now to the next problem. It jumps out of gear if I try to get up on plane, its a gas pig, and smells rich. I have the plugs gapped at 30. Does it maybe need to be bigger?
No the shift rod that goes from just under the carburetors and into the lower unit.----It must be adjusted to a specific height.----Have you looked at the gear oil ??
mikeypb86
So I changed the gear oil and it was black like used motor oil. Went back out on the water and tried with the shift cable disconnected. Same thing. Get into some speed and it feels like it jumps into neutral. Back off the throttle and Back into it and the boat moves again. I've been seeing people talk about flipping the dog around. While it's not the complete right answer, if it's possible I'm thinking about doing it as a temporary fix if the forward gear isn't also chewed up. Then when I have the proper funds I can get new parts. Now, I just watched a guy take his prop shaft out of a smaller motor without having to drop the foot. Just 2 bolts on the bottom. I haven't looked at the foot since watching the video, but I'm hoping I'll be able to the same, and just as easily. I really appreciate you awesome folks helping me out!
