Thinking of getting a sailboat . . .
southkogs
Okay, that the construction type was consistent with what I was used to ... the solution to the floor sounds better than what I was thinkin'
tpenfield
I got the title for the boat in the mail yesterday, so that is a good thing :thumb:
The PO's proof of ownership (from NH) had a couple of typos in it, so I was not sure that the MA authorities would accept it. They either didn't notice or didn't mind. They were more concerned about taxes and fees paid. :)
southkogs
" ... ya' gotta' know when to hold 'em, and know when to fold 'em ..."
tpenfield
Yup, I didn't say anything when I went into the Boat DMV office . . . The guy behind me in line had bigger problems . . .
robgunther87
Nice boat you got there. You might have motivated me enough to buy one myself! I'll be sure to follow your restoration.
tpenfield
Thanks, I thought that the Mariner was a good size, not too big and not too small. There is a good following and the boat is still made, which is a rarity.
ahicks
I would avoid a white deck. Hard to keep clean, and the sails are bright enough (too bright really) on a sunny day. Make it something friendly to your eyes, an off white maybe.
And unless it's going to be a trailer sailer, roller furling is about the best gift you can give yourself.
GA_Boater
Since people can't read that you bought one over 5 years ago, this is closed. Let us know if you want it re-opened, Ted.
tpenfield
Resurrecting my thread on the O'Day Mariner 19. Now that I have a mooring for the boat, I'd better get the restoration done.
So far, I have re-finished the keel/centerboard and fixed blistering on the hull bottom along with barrier coat and some minor glassing.
Still lots to get done . . . I got to take out the old foam and re-foam the flotation chambers and re-finish everything inside and out.
tpenfield
Here is my boat (O'Day Mariner 19) . . . it is waiting for its turn at the restoration process. I've put together a preliminary budget . . . it is looking like $4K.
I'm planning on an electrical system, navigational and cabin lighting, GPS/depth . . . all with solar battery charging/maintenance.
flashback
Guessing you're going to set it on some jack stands to get to the bottom and remove keel.
tpenfield
I am going to need a shelter for the boat to keep it out of the elements . . . After looking online at various temporary shelters and reading the reviews (not so good) and seeing the customer photos (collapsed), I decided I'll make something myself, which will be similar $$$ as the ones you can buy online, but should be a lot more robust.
The boat shown is not exact, but of similar size to my Mariner. This would get covered in 12 mil tarp material . . . I'm thinking of white to get some brightness within the shelter.
flashback
That should work, I guess you could rap it with Tyvek. I see folks do that with additions to their homes around here, often going a year or more without siding.
