Choke plate
Todd Menswar
Does the choke plate in the carb need to sit flat against the chamber? Or does it lean, leaving a small gap (1/8 - 1/4 in.) at bottom of chamber? Would that have anything to do with my cylinders misfiring/sputtering? The compression in the cylinders is ok 110/118. I am getting spark jumping the gap. If it idles at very low speed, it will eventually die out, but I can get it to idle at lower speed while misfiring. Someone mentioned reed valves. Where would they be located? I have a 1987 25 hp Johnson. Thank you.
ondarvr
The choke plate should be completely open when the motor is running, so it should have nothing to do with it not idling well. If it is almost closed, then yes, it could cause it to run poorly.
Is it a miss, or a sneeze back through the carb, a sneeze through the carb is normally from running too lean.
gm280
Todd the choke plate can be a little leaned when first starting and provide adequate choking capabilities. If the engine it already warmed up it should be straight and not choking at all. So when is the engine dying and is the engine on choke at that time. Is the engine already warmed up?
Todd Menswar
Ondarvr, This is when the motor is not running. When I look into the choke plate chamber, I noticed the plate was leaning a little. When I push the throttle bar down , the plate will open. When I release the bar, the plate will close, but not all of the way. I just rebuilt the carb. Should I try adjusting the float again?
Todd Menswar
gm280,
The motor runs fine at any speed above 4.5 mph. It only sputters/misfires when it is at low idle. The engine doesn't have a chance to warm up because it will not idle at a low speed. I have to hold the throttle open to get it to run. This happens with choke on and off.
Todd Menswar
Ondarvr, would you happen to know the adjustment number on the float? Would it be 13/32 +/- 1/64?
Does a 1987 model have a choke plate ?????-------If the throttle plate is not completely closed at idle it simply will not run properly.--------Check the adjustment on the rod that goes to the back of the motor.--at idle there should be about a 3/16" gap or so.----That is often adjusted by folks because when it is correct it " looks wrong " to a novice.
ondarvr
Are you looking at the choke or the throttle plate? The throttle is activated differently than the choke. In that time period there were different types of choke systems, how is yours activated, is it a knob you pull out, pushing in the key, or pushing a button?
The electric start models used the very good electric primer valve and the manual start models used a manually operated primer unit.-No choke plate on them !!!
Fed
Yet the BRP website appears to show some with choke plates and no linkages, cheapskates probably used an old drawing.
